Hi, I have a DF920 without a holding tank and would built it now into the original place.
Can somebody post some pictures from the Installation (not from the inside of tank ). I'm interested in pics from the parts between the holding and the water tank, under the berth.
Where ist the pump mounted?
Do you have a valve to change between tank and the way outboard?
Wich way goes the hose to extraction?
Thanks a lot.
Holding tank searching pictures
DF 920 Cruising 'strandbar'
Some images
Replaced pump and some tubes this winter. Here are some images: https://flic.kr/s/aHsmPzwc7c
There are one inlet from toilet, and two outlets one in the front storage and one via a handpump direct out.
Re: Holding tank searching pictures
Hi Christian,
it’s very very late but thanks for the pictures.
Building the tank is my project for the next few weeks. Changed my hoses from toilette and one valve.
Now I’m welding a water tank in pe-hd.
Do you use pump stations in marinas to emptied the tank?
Best regards
Andreas
Best regards
Andreas
