Mainsail halyard winch
- Your Country: UK, Falmouth
I would like to change the standard starboard side coachroof Andersen winch to a self-tailer for easier single-handed use. The ST equivalent has a slightly larger diameter but would still fit in the existing space. Andersen confirm that the mounting centres are identical, but it is not possible to access the underside of the mounting. Has anyone tried to do this?
Tim Rowley, DF920 Touring 126, "Viva"
- Your Country: The Netherlands, Harlingen
Re: Mainsail halyard winch
I did change a winch once and found that the nuts are laminated into the deck. So there was no need for access from the cabinside.tim rowley wrote:I would like to change the standard starboard side coachroof Andersen winch to a self-tailer for easier single-handed use. The ST equivalent has a slightly larger diameter but would still fit in the existing space. Andersen confirm that the mounting centres are identical, but it is not possible to access the underside of the mounting. Has anyone tried to do this?
Greetings,
Jacob Blom
did you change ?, i want to do the same but i dont know if there is a problem with the spyhood, non enught space.
did you use the self tailing winch with the sprayhood ?
thanks
thanks
I changed a nr 40 Andersen winch (not selftailing), because of a production failure. A friend of mine sails a 920 with selftailing ST 40 winches under his sprayhood. I expect that it is not possible to turn the handle all the way round, but it seems not to be a big problem for him.roby wrote:did you change ?, i want to do the same but i dont know if there is a problem with the spyhood, non enught space.
thanks
As standard there are 8''(200mm) and 10''(250mm) winch handles available. If 8'' is too long it is quite easy to shorten a standard Andersen stainless steel handle just cutting a piece away from the middle and welding the pieces together.Jacob Blom wrote:A friend of mine sails a 920 with selftailing ST 40 winches under his sprayhood. I expect that it is not possible to turn the handle all the way round, but it seems not to be a big problem for him.roby wrote:did you change ?, i want to do the same but i dont know if there is a problem with the spyhood, non enught space.
thanks
