Hi, I have a DF920 without a holding tank and would built it now into the original place.
Can somebody post some pictures from the Installation (not from the inside of tank ). I'm interested in pics from the parts between the holding and the water tank, under the berth.
Where ist the pump mounted?
Do you have a valve to change between tank and the way outboard?
Wich way goes the hose to extraction?
Hi Christian,
it’s very very late but thanks for the pictures.
Building the tank is my project for the next few weeks. Changed my hoses from toilette and one valve.
Now I’m welding a water tank in pe-hd.
Do you use pump stations in marinas to emptied the tank?
