What to call the wires under the floats....
Posted: Wed 22 Oct 08, 3:23
by Oscar
The wires, of shroud like construction that go from the underside of the beams to the hull... Elsewhere on this forum someone calls them "water stays" is that the correct term?
Water Stays waterstays
Posted: Wed 22 Oct 08, 8:26
by Bo Wetzel
Yes, that's what the're called.
Posted: Wed 22 Oct 08, 14:26
by Oscar
At least on your side of the pond..... I will follow your lead! Cheers.
Posted: Wed 22 Oct 08, 20:20
They have been called that on this side of the Atlantic also for as long as I have owned a tri (13 years).
The ones on that boat are small enough so you can them made up by any good rigger.
I think Stew last had them done three or four years ago.
Posted: Fri 24 Oct 08, 3:07
by Oscar
Yup, they look in good shape. Just wanted to know what to call them.
