Front beam structure....
Posted: Mon 08 Feb 10, 6:50
OK, I've got some (more) questions...
Mind you, I have a Canadian built PCMold boat, and it appears they may have been "creative" in their approach to some issues.....
The fixed wings they built have a flange on the hull with a hole in it, and then a long section of aluminum (same as the mast in fact) goes in one hole, through the boat, out the other hole and is bolted in place through the flanges.....
The swing wing appears to be a mod of the fixed wing. The swing "dome with hinge" for lack of a better word, is riveted over the flange of a fixed wing hull, after the aluminum section is removed.
What baffles me is that there is about a 3 inch piece of aluminum tube in the flange, inside the pivot "dome"...... What the hell is that for?
The next question I have is that there is now no tube running through the big box beam over the forward berth. Is this box beam plywood only? Or is there a fiberglass box inside? Is it structural? Or was it only to hide the aluminum in the fixed wing, which is now no longer there......
The reason I ask is because the box beam renders the forward berth all but useless. Maybe a 20 year old can worm his way under there, but I hurt myself every time I do it. Removing the box beam would greatly increase the usable space. But, only if it serves no purpouse.....
It is possible that my boat started life as a FW, and was modified by the factory to be a SW during the transition period between the two.... Then again, I don't know how later SW were constructed.
Maybe I need to pay a visit to Denmark.....
Opinions?
Opinions?
