main halyard
main halyard
Anybody know what the breaking strength requirements are for the 800 main halyard? I have the racing mast with a small square top added to the sail. There seems to be quite a range in breaking strengths between different dyneema and vectran lines, as well as price difference.
Also has anybody tried running any lines bigger than 8mm? I have a length of 10mm I am thinking about trying, but I think it will be too big.
Thanks!
Thanks!
Re: main halyard
Use 8mm Spectra, Dyneema or Vectran, or any other low-stretch line. You are not strong enough to break it.toby123 wrote:Anybody know what the breaking strength requirements are for the 800 main halyard? I have the racing mast with a small square top added to the sail. There seems to be quite a range in breaking strengths between different dyneema and vectran lines, as well as price difference.
Thanks!
I understand that, but I have seen 8mm lines of varying low stretch material ranging in breaking strengths from 7,000 pds. down to under 4,000 pds. I would guess that 4,000 pd. strength would be more than adequate, but there is a lot of force involved. I want to make sure the line will be adequate while keeping costs under control.
Your missing the point, you don't want the line to s t r e t c h .
Buy the line with the least amount of stretch you can afford. Good place to look is APS in Annapolis. Tell them what you are looking for in a high tech low stretch line. Ask if they have any line tails left over - that will save some $'s also. I just did two halyards from them last fall.
You may also look into doing a core to core splice - high tech no stretch up the mast and to the winch, while a cheaper double braid gets spliced on as a tail.
http://www.apsltd.com/c-1485-line.aspx
The main halyard on our 800 is 10mm and it is too big for the sheaves at the mast base. Lots of friction raising the sail. I will be changing it to 8mm low stretch double yacht braid. I used 8mm as my main halyard on my previous boat, a 10 metre Crowther cat with a hell of a lot bigger (and heavier) mainsail than the DF has with no problems at all. The yacht braid is relatively inexpensive and has very little stretch, you can always rig a simple Cunningham downhall to tighten the luff.
cheers,
Paul
cheers,
Paul
