change the forestay and roller reefing ballbearings
Posted: Sun 10 Mar 13, 21:12
by axon22
I want to replace the ball bearings of the roller reefing because it works when the rig is stretched very hard, I will also change the way the forestay. (20 years old)
Have you done this before, as they dismantled the upper ball bearing.
I mean here:
http://fotos.gottlieb.at/displayimage.p ... play_media
Selfmade
Posted: Wed 17 Apr 13, 20:51
by axon22
Now I have repaired the furler (top).
It is a product Bartels.
For photos using the link:
http://fotos.gottlieb.at/thumbnails.php?album=53
If you have the same furler that I can give the name of the ball bearings here you can see on the photos.
1x AXK 2542 SKF Axial Nadelkranz
2x AS2542 SKF Axialscheibe
2x 16004 SKF Rollenkugellager
I also have the lower side of the profile decomposed to conduct a comprehensive inspection.
Nice Greetings from Austria
Juergen
Re: Selmade
Posted: Thu 18 Apr 13, 5:24
by Mika Harju
Here is also some information about this isssue:
http://dragonfly-trimarans.org/phpBB/viewtopic.php?t=15
This might also help:
http://dragonfly-trimarans.org/phpBB/vi ... .php?t=332
Sorry, I did not notice your post earlier
The Same Furler
Posted: Fri 03 May 13, 22:09
by axon22
Hello Mika
Thank you for the nice pic´s very intersing, the DF800 and the DF1000 have the same furler ?!
I have searched for the DF800 furler, now it´s clear to me. why i don´t have found your good Hints.
Jürgen Gottlieb
New bearings
Posted: Sun 10 Nov 13, 21:57
by JP
I have just opened the bottom bearing case of the furler (original part is the Isofurl from Isomat). Looks like the one mentionned earlier by a DF1000 owner, same part numbers!
I will try to get the parts and reassamble this week.
JP Please post photos of the lower drum
Posted: Mon 11 Nov 13, 0:13
I have DF 1000 #15 and have redone the upper bearings, but not the furling drum.
I'd really appreciate photos of your furler drum rebuild.
Thanks in advance,
Lower bearing replacement
Posted: Mon 11 Nov 13, 18:22
by JP
The furling drum and bearing case is back on the boat (DF SW800 No. 163 - 1990).
I bought the parts (same as described above) and made the exchange. You only change the bearings, two solid rings are reused at the same place and position.
Great improvement, might need now to do the same on the top bearing when I lower the mast next time.
Three pictures:
- the furling drum on the deck (not shown, mast secured with two halyards)
- the furling drum open with the bearing case
- the parts inside the bearing case
Re: Selfmade; Bearing replacement of furler to bearings
Posted: Wed 29 Jan 14, 16:06
by Tri-motion
Dear Juergen (axon22),
I have the same top bearing on my DF800. I have also dismantled the housing from the forstay but did not yet managed to get the bearings out of the housing. How did you did it? Could you give me some hints, Please.
Daniel
