Pulleys at mast, ama extension / retraction, etc
Posted: Wed 22 Apr 15, 19:00
by cogniz
The small pulleys scattered through the running gear (4 on the mast base) need replacing.
Anyone have a US source? Or at least dimensions? Are they a particular type of plastic?
Thanks again for the collective wisdom.
Posted: Wed 22 Apr 15, 20:52
If you mean the little fair-lead blocks that change direction of the line, they are common off-the-shelf blocks - look in defender or west marine catalog.
If you mean the sheaves where all lines come out from the mast and/or board, you are dealing with (probably) Fredrikson or Ronstan (who bought fredriskon) hardware. They will be EXPENSIVE and special order. Best price will be from Richard S.
If you figure out the sizes, you might be able to find a harken or lewmar substitute. Lewmar is probably the cheapest solution.
West, defender, and a bunch of other sailing supply places do carry various replacement sheaves, but you need exact sizes. Remove them, measure in mm, then search the catalogs.
The last time I checked to repair a fredrikson block, the part I needed couldn't cost more than $5. Ronstan's quote for the part was $65. I bought a brand new Lewmar block of similar size and load for less than $30!
wow
Posted: Wed 22 Apr 15, 21:36
by cogniz
That's what I call killing my learning curve!!
Awesome info. Thank you.
Mast base sheaves...anyone replace them?
Posted: Wed 16 Mar 16, 19:24
by cogniz
Reviving this post as I've now got the boat out of the water for some much needed bottom paint and general maintenance.
A link to the sheave source would be great. The existing sheaves are chipped, different sizes, etc. So an actual link to replacement versions would be hugely helpful.
I browsed Defender but the metric version of these threw me...Thanks everyone!
