Centerboard Jams
Posted: Sun 30 Jun 19, 19:41
The centerboard on my Dragonfly 35 jams and gets stuck in the up position. The up haul and down haul lines get jammed between the centerboard and the trunk. I have had to take the tabletop off several times to get access and pull the lines free to be able to lower the centerboard.
It looks like there used to be something attached to the centerboard with 2 screws that is missing. I presume it was some sort of guide that prevented the lines from falling between the centerboard and the trunk.
Has anyone experienced this problem and how did you fix it. Or does anyone have a picture or diagram of the missing part so that I can have one fabricated.
