Has anyone installed hatch locks in the amas?
EarthBM
Post by EarthBM »
My preferred system (less visually invasive) would be a lock that acts as a pin securing one of the levers in a closed position (need to make a hole the the hatch and in the lever that would align in a closed position). Not sure what locks are available, a visit to ACE Hardware is in order.
Another alternative is mounting two padeyes on the ama and the hatch and using a padlock.
Anyone?
Search the web for "Ace Key Cam Lock". You can drill a separate hole in the hatch and seal it with rubber washers. I would suggest sealing the key-hole with water-resistant tape when underway.
EarthBM
Post by EarthBM »
I actually bought those from ACE, just waited to install them before thanking you, Larry.
Now that one of the existing handles broke off (the stem that goes through the plexiglass twisted off) I am thinking that whoever made those lever locks might have a locking model.
Does anyone know who makes the hatch locks?
I fixed the one that broke with two screws while underway, no big deal, just esthetically less perfect.
hatch handles
On of my hatch handles is broken. I need to replace it with either original or a new locking type.
Does anyone know the manufacturer of the hatch (mine is 2003 920)?
Does anyone know a source for handles in the US?
Are there after-market replacement handles that will fit?
Thanks,
george
Re: hatch handles
gminkovsky wrote:On of my hatch handles is broken. I need to replace it with either original or a new locking type.
Thanks,
george
The hatches are made by Moonlight. RigRite is the US distributer http://www.rigrite.com/Hardware/Hatch_% ... tches.html
EarthBM
Post by EarthBM »
Outside handle... $35 for a single piece of plastic... These custom parts are ready for 3d printing...
http://www.rigrite.com/Hardware/Hatch_% ... 2H-HOS.gif
Since they are so brittle and I'll need more I'll just replace them with Lewmar. $9.95 for the same part.
Ivan,
do you have the Lewmar part number?
I called RigRite - it's $89 + 11 shipping!
Thanks,
George
EarthBM
Post by EarthBM »
I am thinking http://www.defender.com/product3.jsp?pa ... id=1568522
$54/pair
Just need to look at it in person to make sure I understand how it will fit
For a difference of $35/pair why bother? You spend more than that on dinner for one. If you could afford a DF-35 just get the right part.
I can't afford a DF 35!
I have a 11 year old 920!
The difference is $128 for 2 (including shipping). 54 + s/h vs 89*2 + s/h.
I actually found just the outside handle for $10 + s/h.
Still need to confirm that it will fit...
EarthBM
Post by EarthBM »
Can report good experience with contacting BSI directly (bsidk.com -- marine -- contact). Bought 10 outside handles at $8/each plus shipping.
BSI part XO2206731
